None of the above good suggestions can compare with a good quality sail slide system. Most systems are comparable, require a track and cars but you will find that, compared with slides or a bolt rope, the difference is jaw-dropping in terms of speed and ease with which you can raise and lower the sail. Obviously the price is a consideration but of the few I have had, the Harken Battcar system, which is only slightly more expensive thean the competition, is by far the best in terms of both durability and minimized maintenance required.
Your boat and mine have pretty substantial main sails and the main goes up with ease and down like a rock. We've never had any issues with our Harken system since installed when the boat was new almost 20 years ago.
