mainsail sheet
annaro
Sep 18, 2013
5
Oday 19 Chambly
The lench of the mainsail sheet on my O'DAy 19 is 24 feet and seems to short to me. Anybody can tell me what is suppose to be the lench of that sheet ?
Thank you.
Dec 20, 2011
118
Oday 19 weekender New Milford,Ct.
Sorry I don't know the length of mine but too long is better than too short.When you are fully sheeted out for downwind,is there any line left in your hand?I would prefer there to be at least 5 or more feet to spare...Barry
annaro
Sep 18, 2013
5
Oday 19 Chambly
Thanks for your answer Oliversdad. I wonder, when I m fully sheeted out if the boom should be close or touch to the shroud ? If yes, is there any chance to tear the sail on shroud speader ?
Mar 20, 2012
3,983
the boom should not touch the spreader, but the sail will... in time it will chafe thru the sail, but once you see the wear point (by the dark staining where it touches), you can reinforce it with a patch of sail tape BEFORE it wears very much and prevent any problems.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
My mainsheet has a stopper knot tied in it to where the boom goes just short of the spreader for downwind work, and then I've got maybe 3-5 more feet after that. I figure just to make it easy to grab the sheet if I need to when the boom is all the way out, as opposed to digging the stopper knot out of the block. This is for my end boom sheeting, of course. Also, the boom is set a few inches shy of the shroud, just in case there's a crash gybe, I don't want the boom taking abuse from the shroud. Of course, with end boom sheeting affixed to the backstay, there might be a fair amount of stress all around for crash gybes.
Then again, for some racing dinghies in big wind, I've seen videos around the gybing mark, and every gybe is a crash gybe. And every time I shudder as the boom whips around and stops short, that the whole rig is gonna come down....
If your mainsheet is too short, such that the boom stops actually feet from the shroud, I think that's bad, because on a broad reach or run, I think there's a higher chance of inadvertent gybing.
Brian
annaro
Sep 18, 2013
5
Oday 19 Chambly
Thank you for answering. Because of you and Barry, now I know what to do.
Thank a lot to both of you again.
Jun 2, 2004
1,948
Oday Day Sailer Wareham, MA
Here is the rigging specs as listed by O'DAY. 24' for the mainsheet is too short, correct length is 30'
O’DAY 19 RIGGING SPECS
(Taken from a 1979 O’DAY memo)
Running Rigging Specs.
All Lengths and specifications are approximate and are subject to change without notice
Main Halyard: 5/16” x 53’
Jib Halyard: 5/16” x 47’
Mainsheet: 5/16” x 30’
Jib Sheet: 5/16” x 30’ (15’ each side)
Mainsail Outhaul: 3/16” x 9’
Spinnaker Halyard: 1/4” x 45’
Spinnaker Pole Lift: ¼” x 21’
Spinnaker Pole Downhaul: ¼” x 21’
Spinnaker Sheets: ¼” x 32’ (2x)
Genoa Sheets: 3/8” x 40’ (20’ each side)
All running rigging is typically double-braid Dacron (Polyester) rope
Standing Rigging Specs.
Headstay: 1/8” x 23’8”
Upper Shroud:1/8” x 22’7”
Lower Shrouds: 1/8” x 11’4”
Backstay: 5/32” x 27’7”
Backstay piece below mainsheet attachment triangle: 5/32” x ?
All Standing rigging is SS 1x19 type wire and lengths are with turnbuckle (where applicable) closed, from eye to eye (most riggers measure with turnbuckles half-closed, so be sure to note this and/or bring old rigging to rigger to measure for replacement)
annaro
Sep 18, 2013
5
Oday 19 Chambly
thank you Sunbird for O'Day 19 rigging specifications. I keep that preciously for future uses.
