Mike
I have a '79 Hunter 33 purchased last year. We use our first sailboat for cruising and not racing. This year the budget is tight because we are going to install a CDI roller furling and good condition, used headsail (135% genoa). Replacement of the mainsail will probably wait until spring '04. It is badly stained (probably never cleaned) and probably stretched out of shape. In addition, when I loosen the downhaul to tighten up on the leech the boom interferes with the bimini. Is it feasible to have this sail cut to eliminate this problem (probably 6" off of the foot at the clew to nothing at the tack)? What is the best method of cleaning the sail concentrating on the stains? Or is this ridiculous and futile (the mainsail should definitely be replaced)? Thanks for your time and expertise.
