H31_83-87 Mainsail outhaul
You did not specify exactly what H31 you have. I have a 1987 H31.When my outhaul died, I had to remove the goose neck from the mast and drill out the rivits. Then I found that the outhaul (wire) is attached to a pully (which broke) that had the control line going through it with one end tied to a loop that was rivited to the side of the boom. The other end (control line) came out the bottom of the boom, creating a 2 to 1 ratio on the control line.Would not have been able to replace the pully without taking the goose neck off. While I was in there I replace the outhaul control line also. Well, maybe some others could have replaced the pully without removing the goose neck, but not the control line. I took the "might-as-well" approach, might-as-well replace the whole thing while I had it taken apart.bill
