MAINSAIL - Outhaul Clew - HELP
Dave Royce
I sent my sails in for cleaning and the mainsail came back with a modification???? (I think) At the clew for mainsail there is a metal U-shaped piece attached to clew on the bottom of the sail. The rope feed in the track stops just infront of this. I do not recall this piece being on the sail when I removed it. It appears to be for a sail slug or something like but I do not have one. HELP...the sail pulls out of the aft end of the boom when hoisted. It did not do this before the sail was removed. Was it modified? Did I lose a piece? or am I crazy.....Great weather, good winds, outhaul clew lashed to boom to keep it in. The sail looks really good but hate having to tie it to the boom, I think it looks tacky.....
Steven Gautney
Tack is attached to a pin at mast / boom junction.
Clew is then attached to the outhaul sheet (that runs inside the boom and is cleated at the mast. I'm not entirely sure what you are asking . . .the clew attachment point is usually a gromet in the corner of the sail. On my 23.5 the main clew does not reach the end of the boltrope track. The "u-shaped" device sounds like a reefing hook . . .usually near the boom/mast junction . . .and used to shorten the tack when reefed. I'm not sure we are speaking the same language . . .but I'll try to help . . .
Bob Gravenstine
Missing Slug
Go back to the sail cleaners and have them give you a new slug for the clew. It attaches with the shackle you now have on the sail. With the slug in the boom, your sail will stay in place.
Dave Royce
New Slug
SailCare is sending 2 new slugs..... Thanks for the input
