Mainsail B331 not fully furling into mast
134
Beneteau 331 Chicago (DuSable)
I added a new main this year. Long story but got it for $200 from the factory that makes them. Anyway....installed the nice crisp sail and was working great except 90% of the time it will not fully retract to the black mark they put on the main to show that your fully furled to the UV patch on the clew. I'm usuall about 6-8" shy.
Sometimes...it does go to that correct point, usually not.
thanks!
Craig
Mar 5, 2008
58
Beneteau 43 Alameda
Are you 6-8 inches shy due to running out of furling line or just unable to furl it all in?
Are you keeping the same level of resistance on the outhaul while furling the main?
I had a 331 and can't say I had that problem on the main as I was extra careful about the outhaul resistance to keep creases out of the main but had seen it on my jib when furled too loose, too sloppy on my part.
Nov 2, 2008
134
Furling line is plenty long. This just started happening. Seems I solved it yesterday during the holiday weekend here in Chicago. While the main was fully outhauled I released the boom vang and topping lift as well as a little slack in the mainsheet. This resetablished a "natural" set of the main.
Anyway when I pulled the inhaul in the main fulrls up nice and smooth and even and went all the way in to the black line that shows your up to the UV panel.
Did this several times and worked well. Also seemed like less muscle required.
I summary I feel the foot of the sail and the leech are at equal tensions which enable it to roll nice and easy and flat. I think before I had some relative slack in the foot which bunched up.
Anyway thanks for your input.
