C
Capt'n Bob
To the Liberty Cub boat sailors.In the Cup video of this series it shows the Hunter 35.5 boats with a main sheet block and tackle attached to a traveler that was position just fwd of the wheel and pedistal.TJ, I noticed in one of your pictures that your main sheet appears to be in that configuration. If so, how do you like it ?? Does it take a lot of line as the boom is let out to the shrouds on a downwind run ?? Do you see or have you experienced any advantage to this end of the boom sheeting ??Akan, Did you add this main sheet traveler modification to your 35.5 when you added the deck top jib sheet track and jumper strut on your mast ??TJ, Does your Liberty boat still have the jumper strut on the fwd top side of your mast for the purpose of adding tension to the forestay ?? If not have you gone to running back stays or just the usual adjustable back stay ??RD
