Main Sheet
BoulderDon
We just bought a 1985 Hunter 31 and we're curious about the routing of the main sheet. Right now it runs through the dog house and into a clutch. There is no way to quickly release the main sheet - you have to release at the clutch. This seems a dangerous layout to me and I'm considering replacing the clutch with a cam cleat. The jib sheet does also run through the left leg of the clutch so I'll have to reroute it. What is typical on other Hunters? Don s/v Sunday Silence Cape Coral, FL
Aug 13, 2005
23
Hunter 31_83-87 Ventura, CA
The system is fine. If you release the clutch full forward the main sheet will run free. You should be using your traveler more. Dennis
Apr 16, 2006
75
Hunter 31_83-87 Key West
Same setup - works fine
I've got the same setup on my 83 Hunter 31 and never had any problems releasing this line.
Aug 22, 2006
8
Hunter 31_83-87 Cape Coral
Thanks for the comments. In other boats I've sailed you could release the boom with a simple pull to open the cam - particularly important if you have too much wind and need to release the sail immediately. Sort of the emergency brake or panic button to get the horsepower off of the sails quickly. With the clutch design someone has to move forward and put a hand on it, it cannot be done from behind the wheel.But then maybe I just have short arms!
