I plan on upgrading the fiddle block on my main sheet tackle. Currently it is a Schaffer 4-1 system with the larger sheave appearing to be 2 1/4". White material. Bottom fiddle is black and seems to be newer.
First, is the sheave size the outer diameter or the bottom of the groove where the line runs?
My turning blocks for jib sheets and halyards are all Garhuaer Marines 25 series blocks which is listed as having a 1 3/4" sheave. These were recommended by Garhauer.
Their 30 series fiddle blocks have a 2 5/8" sheave.
Harken's main sheet load calculator shows my main sheet load to be around 628 lbs. at 25kts so both are well above SWL listed.
Main sheet is 5/16" line.
My thinking is the 30 series fiddle block would be a bit over kill for my 25' boat.
Yes?
No?
I will be asking Garhauer also but I appreciate your thoughts.
Yes?
No?
