Main Salon Sub-flooring for Hunter 44DS
Jul 25, 2013
5
Hunter 44DS St Petersburg
Hello all,
I had a leak in the shower of the main head. It was one of those slow ones you don't see until it becomes a problem. I need to replace some of the sub-flooring in the main salon. Does anyone know if there are sources for this material? It is plywood with a thin white laminate. Approx 19/32" to ⅝".
Thanks
Laminated Plywood can be found in most plywood retail stores.
Are you sure you want the same product installed?
It may be a good time to identify the design needs of a product placed there. Is it random that the leak occurred and caused this issue or will it happen again? Perhaps there is a better non-wood/non-porous alternative that would serve your needs for a longer time period.
Just because it was done at the time your boat was built, does not mean you should automatically repeat the same action.
