Main Sail
Jul 17, 2011
21
Beneteau oceans 321 Saint John
We have a 1997 Beneteau Oceanus 321. Require a source for new sail slides for the main.The slides are T shaped and made of nylon (plastic) also require the nylon shackles that attach slides to sail ,don’t have the sail handy at the moment to get dimentions
Will have hem later in week
Thank You in advance
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
It sounds like you have a traditional main sail?
I just purchased a new main for my 1988 O’Day 322. I think the original sail was made by Doyle. A PO had replaced the headsail with a UK 130 Genoa.
I reached out to some local (Chicago) lofts (UK, North Sail) as well as several on-line sources (SBO, FX sails).
North Sail came out and measured my mast (which was reassuring) and their price was reasonable.
I wanted a full-batten, loose foot, cruising sail and the sales guy told me that I should consider a Sailtrack to reduce friction. My old boat had full battens and a ball-bearing batten cars. I was convinced and purchased the Tides Marine Sailtrack, along with the new sail from North Sail.
Greg
Jan 24, 2009
451
1981 Cherubini Hunter 27 Shipwright Harbor Marina, MD
If you are looking to replace just the slides and the webbing that holds them on using your own sewing machine, Sailrite stocks them. Otherwise take the whole sail to a loft and let them give you a quote.
