main sail slides
dan
has anybody tried using any type of lubricant on the mainsail slides does it make a difference?
ed21
Jun 7, 2004
55
- - baltimore, md
shouldn't be needed
I've used a little spray silicone. Not sure if it helps much. If you're having trouble w/ raising sail, make sure slides & mast track are clean & that you have the right size slugs for the mast track. Slugs could be worn out.
RobG
Jun 2, 2004
337
Ericson 28 Noank, Ct
Mclube Sailkote
Mclube Sailkote - Clean the track well with a solvent and soft cloth. Spray it in trying to hit the inside of the track where the slugs contact. I used a piece of cardboard folded into a "T" to deflect the spray.Spray the slugs as you bend them into the track. it made a HUGE difference for me.
Feb 9, 2004
311
another vote for Mclube
Hi dan - I'm with Rob; I use that Mclube stuff for lots of things, but especially for the sail slides! Good to keep a can aboard for a myriad of uses, such as freeing tight turnbuckles, blocks, travellers, etc. Best, Trevor
