Mast Bend Measurement
The mast bend / luff curve is indeed a factor in any mainsail design, and would usually be measured by the sailmaker if you were having a new main 'built'. A frac rig with single swept back spreaders could have at least 4-6 inches of pre-bend, and be significantly different from a mast head single spreader rig with a stiffer straight mast and straighter luff. Also, depending on the Hunter having or not having a fixed back stay, you could find a lot more roach on the Hunter Main than cant be accomodated with a fixed backstay on the Irwin. You definately would wamt to trial hoist the main to see if it will work and be able to return it. I would think you could hoist it to full height, tighten the outhaul to maximum and see if there is a lot of extra depth or wrinkles in front of the battens. You won't want a mainsail that is too full and can never be flattened.
