Access the Keel Bolt Through Battery Well
Kevin,I was able to trailer my Mac 25 and use an automotive floor jack to take the strain off the keel bolt and replace it. Use caution doing this as the keel will fall to the side (crushing whatever it hits) if you lower it too far. An aligning bar was a must in my case to get the keel lined back up. The one question I have is did it just start leaking on its own or did something happen to make it start leaking. As I recall, there should be a stainless steel washer and a rubber gasket on each side of the keel bolt where it goes through the trunk. A generous amount of silicone should also be used between the rubber gasket and the keel trunk. When you put the bolt back in, do not turn the bolt itself, but rather tighten the nut only. I used a Nylock nut on the new keel bolt. I would recommend a new keel bolt if you get to the point of pulling the old one out. Stainless steel is recommended. The keel lock bolt should be set up in much the same fashion as the keel bolt (with washers and gaskets), this could also be a source of leakage. Again, be careful if you get to the point of removing the keel with a jack as it can easily slip if you lower it. Clayton
