Main Halyard
Peter Barton
Does anyone have the correct specs (length, thickness etc) for a main halyard? My old one is badly frayed where it is tied off at the mast. I have the Cherubini 25 footer 1977 model. The options are 100% rope and wire to rope. For gentle cruising on the Potmac and Bay, what would anyone suggest for a replacement? Thanks Peter
Jim
halyard
OME was 61' of 3/8 yale cordage with an eye splice. The halyard on my h25 is 1/2" with a snap shackle and somewhat longer than 61', but I don't know the exact length. Hope this helps. Regards, Jim
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
H25 Line size
Wire-to-rope is no longer necessary, now that we have improvements in textile cordage over the last 40 years. I would recommend Sampson XLS or its equivalent (a little cheaper than NE Ropes). I am using 7/16 for all my major running rigging and 5/16 for the reef, downhaul, outhaul, and pole-control lines. Also-- for double-sheave mastheads, even if you use the second main halyard just as a topping lift, there is NO logical reason to make the secondary a smaller-sized line than the primary. Under the conditions in which you'll need to use the secondary as a back-up, you'll want it to be as strong or stronger than the one that just failed! One issue in the diameter of line is the comfort of holding it. There was at one time a range of large-size low-strength lines just because of this-- I am sure it was phased out because you couldn't guess its strength for applications based on its size. But truly anything under 3/8 is a pain to hold onto. Make the mainsheet, even on a dinghy, 3/8 or 7/16. You'll be glad you did. JC 2
