More neat stuff for lines aft
Yes , The items from Catalina Direct are very nice. I have put on the mast plate, and it's well worth it. I also put on a four sheeve deck organizer from Garhauer Marine, which supplies many items to Catalina Direct. I went with this deck organizer, because it has the same footprint as the two sheeve organizer that was on my C22, and it allows me to run four lines aft on each side. From the deck organizer, I run my lines down on the cabin top, through a four hole block/fairlead, which can be had at www.colligomarine.com This helps me keep my lines neat and out from the poptop when I open and close it. After the lines go through that, they go through a triple rope clutch. I have the spinlock triple, which works great for me. That is mounted on the cabin top as well, then the lines pass a cabin top mounted winch, a lewmar #6. This is mounted at the very aft end of the cabin top. Then the lines are draped over the side of the cabin top into the cockpit, and hung on the cockpit wall when not used. These handy line organizers, to hang up your lines with can be purchased at West Marine, and some very nice ones can be bought at www.schaefermarine.com They are called handi-hangers, they have wall mounted ones and rail mounted ones. The setup that I described above is one both the port and starboard side. A very good site for information on C22's is www.chipford.com , go through his projects, and check out "other sites" . He has some great links to help fellow C22 sailors. Also www.c22pdx.org is great.
