Main Engine Vented Loop
Dec 25, 2000
5,962
Well, what an experience. Took the fam out around the islands for a two week cruise during the July 4 celebration. Noticed a more than normal amount of sea water in the main bilge after each shut down. Also, quite a bit of seawater in the bilge beneath the engine that was never there before. Wha sup? Checked all the obvious hose connections, stuffing box, packing glands, etc., etc.., etc. No noticeable water leaks.
After they left for home in Texas, I went back to the boat for a more serious examination. My first thought was the Genset, so ran it for several minutes checking all the points of water connections with a bright flashlight. Nope, zip, nada. Shut her down and fired up the main engine and went through the entire compartment with a bright flashlight. Still nothing. Then I happened to glance above the Genset platform and just by chance noticed water spitting out of the connection where the vacuum breaker connects to the mixing elbow located high up on the starboard bulkhead. Its purpose is to prevent sea water from siphoning back into the main engine after shutdown, since much of it is below the waterline. What I also learned in the process was that the sea water pump brings water in and pushes it through the system; heat exchanger, mixing elbow, exhaust. The vacuum breaker works like a joker valve. It closes when water is pushed through the system and opens to allow air to break the vacuum. Boy was I confused until Jeff Gay cleared things up for me.
To do all this examination I had to remove the front hatch to the engine compartment and even with one long arm I could just reach the vacuum breaker. When I touched it, it just fell off into my hand. The breaker is plastic and the vented loop is one inch SS tubing. The breaker itself was in good condition, but the adapter used to attach the two failed due to age fatigue. I tried an easy out to remove the old piece from the loop, but nope. What if I were to just use some adhesive or epoxy to stick it back on? Easy enough, but just temporary. This fix needs a permanent solution.
Then I began the hunt for a replacement. Rather than name names, some never called me back, even after follow-up calls. At the time it seems a complete new vented loop was in order, one made of Marelon, perhaps, at a cost of between $40 - $70 depending on suppler. But all I really needed was this two step down (5/8" to 3/8") plastic adapter.
Access to the vented loop was another problem. No way from the front, unless I moved the Genset, a major project. Instead, removing the 50 pound Xantrex charger/inverter seems a better solution with rear access. But first the adapter. Jeff Gay at Harbor Marine in Everett has always been very helpful, especially back when I had a Genset water pump impeller problem, and very knowledgeable when it comes to marine systems. He offered over the phone a new Jabsco vented loop, but what about just the adapter? Bring it in and let's take a look see.
Walked back to Jeff's office and presented to him my broken adapter and working vacuum breaker and he said, "follow-me". He went to this rack of bins on the floor looking for this two step adapter and lo and behold he had one in brass for $8. Now it was time to get serious. He gave me tips on how to remove the old broken piece out of the vented loop by using a vice to hold the loop and a small chisel to chip out the old material.
The biggest chore was to remove the charger/inverter. I installed it myself several years ago, so was a bit familiar with what to do. Got it out, which made for much better rear access with two arms rather than one and removed the vented loop. The old material popped right out after chipping out parts of the old broken nipple. Jeff suggested using liquid thread sealer, which I did, when threading on the new adapter to the loop as I also did with the vacuum breaker. Put it all back together and did an engine test. No leaks, period. Then a sea trial was in order just to make sure, so off I went for a week long trial around the islands. What a great feeling. I suppose I could have hired a tech to do the job for maybe $600 to $800 or more. Rather do it myself, so I know what makes all the systems on this P42 beast work. I remember looking at the vented loop over the years, but never paid much attention to it. I always assumed, by mistake, that it was part of the sewage system. Now I know.
Thank you Jeff Gay, Harbor Marine, Everett, WA.
The pic below shows the one inch SS vented loop behind the large black hose.
The pic below shows the vacuum breaker and broken adapter that is connected to the top of the vented loop. The right side of the adapter shows brown stain where the 3/8" threaded nipple was once a part of the adapter, now stuck in the vented loop.
The pic below shows the original vacuum breaker that still works with the new brass adapter.
The pic below shows the vented loop back in place with the new adapter and vacuum breaker installed.
578
Bavaria 35E seattle
Thanks for mentioning Harbor Marine. I plan to try them sometime soon. They were recommended by another boater, too.
Sep 26, 2008
742
Hunter 340 0 Wickford, RI
Great posting. Very pertinent information. By far one of the most overlooked parts of a boats system. I found my vented loop was “going” to fail on me, completely by accident.
After having a new replacement PSS Bellows replaced. (Total opposite ends of the boat). My original PSS never had the vented tube coming from it. The new tube was simply routed up and over the highest part of the back of the engine. I was installing an overflow container for it and saw the vented loop.
While zip-tying the tube next to it, I hit it. And the plastic breaker vent just fell off. Lucky me!
A disaster averted!
I was always going to get a new breaker vent, as a spare one, but never did.
Your posting is making me get one now.
Thanks for the information. Great post for everyone to read.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
The design people who hide critical parts like that should have to do the repairs.
Jan 12, 2019
114
Hunter 340 Narragansett
Well you piqued my interest. Where do I get the Vacuum Breaker Vent? I've looked at mine and it seems fine, right now. Solid and easy to get at on my 340. From a quick outside measurement of the exposed threads it looks like it's 3/8". But I can't find one. Any suggestions?
Oct 26, 2010
2,182
Hunter 40.5 Beaufort, SC
Wow - it must be really hidden on my 40.5? @Terry Cox I recall you had a 40.5 so any tips on where to find it.
Smokey
Dec 25, 2000
5,962
Hi Nicole. Typically vendors sell the vented loop and vacuum breaker together as a unit. Marelon made by Forespar would be a good choice that you can get from Defender here: Forespar Vented Loop - Sizes: 3/4" and 1-1/2"
If the vented loop is in good condition, check the vacuum breaker. If that is good, you should be fine. As far as getting a vacuum breaker separately, that will require some hunting. Unsure of where to advise you look.
Dec 25, 2000
5,962
Smokey
Different model boat here, Smokey, so not sure where to look on your boat. Likely it will be near the main engine, high above on a bulkhead, like on ours.
Sep 26, 2008
742
This is a photo of my original stainless steel vented loop on my 340. Minus the plastic vent on top. It measures 1/2 “ OD and the vent threads are 3/8”.
I probably fell into the same situation of not being able to find just the vent top valve and the whole thing went into storage as, someday I’ll get one.
You can still get the stainless steel versions if thats what you want to replace it with though. But just the top vent, I’m still looking also. If I find one I’ll let you know.
As far as location, like Terry says, it has to be high over the back of the engine compartment somewhere.
5,962
You're welcome. Unable to rate their marine repair group, due to lack of experience with them. Regarding their store inventory, very good. Ordering the part you need, also very accommodating. If you want expert advice from Jeff Gay, walk past the main floor and back to the transmission shop where you will find his desk. He has been very helpful when up against a technical problem that requires his expertise.
senang
Oct 21, 2009
316
hunter 38 Monaco
I did away with the vacuum breaker vent in the engine room. Vetus has a model where the vented loop has a permanently open small hole, connected to a small diameter hose leading to outside the boat. Install 4“ to 6“ above the waterline. When you start the engine check if this peeing. All is well, no maintenance or access problems. No salt water in the engine room. Simpler is not possible, no moving parts.
Likes: All U Get
