Main Breaker
TnJ
Mar 17, 2008
2
Hunter 31_83-87 Beesley's Pt.
Hello,
The 30 amp main breaker on the shore power (120V) side of the panel of my 1984 H31 is on the fritz and needs replacing. West Marine has a 30A breaker but it's different than mine. Mine is a double-pole but only has a toggle on the left half. The one WM has is also a double-pole but has two toggles and they are tied together to act as one. Can I use this to replace mine? Drilling another hole in the panel is no problem, but I want to make sure it's electrically ok. Also, mine has a terminal on the back that has a green wire (I assume ground) connected to it. Their's doesn't have this terminal. If I can't use their's, does anybody know where I might find what I need? Any help with this would be greatly appreciated. Thanks, Ted Vaughn, Atlantic City, NJ
Dec 2, 1999
15,184
Call Hunter
Call Hunter, they can usually help you out. You may be able to find the mfg on the old one too.
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
Same thing
The two breakers are the same - the fact that one has two toggles and the other has one does not mean they are different - that is only the mechanism that you see when you flip the breaker on and off.
Just make sure the current rating is the same - you'll be fine.
The surprizing thing to me is that you only have two poles on your main. I have three - the third is a ground.
