Magnum inverter/charger tutorial?
Rodd
Pearson 424 East Hampton,NY
Happy New Year to Maine and the Group!
About a year ago we had a thread regarding how to install a Magnum Inverter/charger. Maine responded saying such a tutorial needs to cover a lot since there are a lot of incorrectly installed inverters. Wondered if you were still contemplating one of your great presentations on inverter install?
Thanks Maine!
Rodd
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
Seems like a good idea - I can't recall ever seeing a good inverter install tutorial.
mt, one of the reasons I'd think is that the installation of in inverter and even inverter/chargers is the simple part.
The hardest part is designing the SYSTEM, both sides, so that the right equipment can be selected.
Issues that are major determinants include Management - does the AC side have an ATS or will manual switching be required; does the AC inverter side feed separate sub panels or the main panel which would require managing loads; and DC system support side.
These are issues that have been long and detailed enough to warrant complete BOOKS and websites. :)
Not sayin' it couldn't be done, but it'd be a pretty hefty investment to do so. In many cases, the list of the options available in system design and management alone would be longer than the How Do wire up and mount the equipment: it's what it's connected to that's so critical.
Like, for example, explaining an ATS to unknowledegable skippers alone would be a half page.
Sep 28, 2008
922
Stu, I agree. There are many variables when installing an inverter/charger. Actually most manuals I have seen cover the basic options fairly well - even Xantrex.
I answered this post because it looked a bit lost - no replies in 3+ weeks.
Feb 6, 1998
11,701
I will eventually get to it but building the new web site is taking most of my free time.
Rodd
Thanks Maine!
and yes Stu, the system is key. I am interested in the ATS end of it myself. I feel power from inverter to Master breaker on panel lets one select which loads to use that are compatible with the size inverter one has installed.
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
Thanks Maine!
Can both shore power and inverter be connected to the AC master breaker? I was just planning to use my Xantrex Prowatt sw2000 as a stand alone for powering occasionally used AC appliances. It never occurred to me to use it to power the outlets.
RTFM. F stands for funny.
Can both shore power and inverter be connected to the AC master breaker? NOT at the SAME TIME if BOTH are ON. You'll, literally, blow things up!!!
One MUST think of an inverter as a SOURCE of power, just like your local utility through shorepower, and generators.
5,818
Hunter 36 Punta Gorda
I have a 2000 inverter/charger on my 2007 H-36 and the inverter yes does supply
power to all my outlets and microwave and anything needing 110 power when the remote is pushed for inverter.
But I also have (auto switching) to prevent shore power and inverter power to main panel at the same time and some boats use some kind of manual rotary switch to prevent shore power and inverter at same time.
Nick
Sep 2, 2011
1,041
Stu, have you read the Xantrex manual? I have, cover to cover, and there is no information on attaching the AC output to loads in any other way than plugging them into the front panel outlets. In fact, the two wiring diagrams don't even show AC loads in the circuits.
Obviously!
Sep 28, 2008
922
Nick's SW2000 has a built-in transfer switch. That means either all or a portion of the shore power passes through the inverter. When the shore power is present the inverter passes it on to breakers for outlets and is a battery charger. When the shore power is not present the inverter produces AC power from the battery bank and powers the same outlets.
Sep 2, 2011
1,041
How is it wired into the system? Put a 3-prong plug onto some 14/3 triplex wire and connect to the AC panel's main breaker from the inverters front panel?
Sep 28, 2008
922
Because it is both an inverter and a charger it has both an AC input and an AC output. These are hardwired - there are not any 3 prong plugs on this model.
Sep 2, 2011
1,041
Oh, mine is the PROwatt SW2000 inverter only, not a charger/inverter.
Sep 28, 2008
922
Correct, your PROwatt SW2000 is a stand alone inverter. Some inverters and all inverter/chargers allow for connection to external outlets. Some inverters that are not chargers have AC pass through capability as well.
You could connect an extension or powerbar to your inverter to make using appliances more convenient.
Feb 6, 1998
11,701
No not without a SHORE/OFF/INVERTER transfer switch.
This is the best way for that type of inverter. I generally advise that type of inverter be wired only to dedicated inverter only separate outlets and not to the ships AC panel.
Sep 2, 2011
1,041
[QUOTE="Maine Sail, post: 1273187, member: 2"|
This is the best way for that type of inverter. I generally advise that type of inverter be wired only to dedicated inverter only separate outlets and not to the ships AC panel.[/QUOTE]
I think I'll just use its own outlets. KISS!
btw, just got my Sterling 60A charger. Nice!! Plan to install it Monday
Thanks
Feb 6, 1998
11,701
Did you order the ProCharge Ultra from me? I know I shipped out a couple of 60A chargers last week. But screen names and bill to names are different.
