Connection Kit
You will also need a Propane Barbeque Low Pressure Connection Kit, WM # 183626. It is a Tee valve that allows you to connect the A10-220 control valve to your gas line. When you want to use the gas grill, connect the Control Valve to the grill where the propane bottle would normally be- it is a quick connect fitting - turn on your gas system as if you were using the stove, then open the Tee valve. You will be able to use the gas grill and the stove at the same time, if necessary. I installed this system a couple of yers ago and it has worked without a problem. I always prop the gas locker open with a block when in use, so the locker won't acidentally close on the gas line.
