Recently acquired a Venture 25 and am repairing the broke keel cable and trunk. Several concerns but my primary question is the alignment of the keel cable wear pin in relation to where the cable end connects to the keel. The hole in the keel for the cable bolt is 4 inches forward of the hole in the trunk where the wear tube is mounted. Seems like the cable will have excessive bending especially in the up position. Almost like the keel is too short or located too far forward. Is this typical or should the holes be in perfect alignment in regards to forward aft?
Also the cable will be connected to one side of the keel via the bolt. Which side of the keel should the cable attach?
Thks all
Thks all
