I don't think that...
that you really need a Flicka to do some coastal cruising . Cap E is right, it is a true blue water cruiser. It has a full keel and is made for crossing oceans. Dave, in 45 knot winds and 10ft seas, you and I are going to be puckered, no matter what boat we are in(I am a lake sailer). I do not want to be out there in my 26S, but that does not mean that the 26S is inapropriate for coastal cruising. Even on lakes, I listen to the weather reports, watch the sky, and head for shore if the conditions deteriorate. The flicka is a beautiful boat that will probably get you through any storm when running to port is not an option. But it is heavy and will be slow in light airs, the full keel will not let you explore shallow areas, and it will not be trailerable in the same sense that a mac is. It will reqire a powerfull truck(I pull my 26S with a Chevy Astro van), and you will probably need a crane to put it in the water. They are also very expensive compared to a mac or even a Catalina or a Hunter. It is a great boat and a good suggestion, but it is a realitively exspensive boat and I am sure that most Florida sailers with coastal ambitions start with less.
