Yes, the handle will stay up.
I've suggested to Raritan that offer a telescoping pump handle, but they haven't bought the idea. Seems to me you could make one using a section of telescoping boat hook...I THINK the diameter of the outer sleeve and the pump handle are the same...I KNOW the pump handle and a broomstick are the same diameter.So be creative...you have nothing to lose by it. However, I wouldn't shorten the handle much...it's designed to provide the right amoung of leverage for the pump.And while I have the floor...a week or so ago, someone asked why the PH II is a better toilet than the Jabsco (or any of the others that cost less than $500). I knew it was a more powerful pump, but this explanation, posted by Vic Willman (tech services manager at Raritan) on another explains in detail what makes it a more powerful pump: "The diameter of the piston of the PHII is 2 1/2 inches. The diameter of the piston of most other manual toilets is 1 3/4". Now this doesn't sound like much of a difference, but given the same length of stroke up and down, for demonstration purposes we'll say 2 1/2 inches for each head that we're considering. When you calculate the cubic inch capacity (displacement) of the PHII with a 2 1/2" diameter piston, it comes out to a little over 12 cubic inches. If you do the same calculation for a pump with a 1 3/4" diameter piston, with the same 2 1/2" stroke, the cubic inch capacity is only 6 cubic inches. So, to put that all into English, the PHII will pump twice as much per stroke, as it's competitors will. Adding the lever-type handle, there isn't as much actual effort required. So, in a nutshell, you only have to pump half as many times to flush it, and your arm doesn't get as tired. Plus, with the lever handle, you don't have to bend over as far, with your nose practically in the bowl, while you're pumping it."
