Ok now I am baffled
In spring commissioning I check all systems. I turned on the breaker to macerator and pump went on, autopilot spun wheel and then breaker flipped.
I figured switch bad and shorting out since throwing the breaker should not turn pump on
Ok i take switch out of circuit and separate leads. this should be like switch permanently off
Now i throw the breaker and pump runs autopilot tries to correct again( whats up with that ........ Magnetic ??)
( in ches. bay we pump out all the time so this system ( macerator)is very seldom used)
How is power getting there??
FYI I have done no rewiring only elecrtrical change was having new batteries installed by marina this spring prior to all of the above
HELP??????????
HELP??????????
