On our 38 Hunter, on the control panel there is the Macerator switch. Is this to be turned on at all times or for certain periods of times after use of the restroom?
Neither one...that switch has nothing to do with toilet operation. What's commonly referred to as just a macerator is a macerator PUMP. As others have already said, it should only be turned on to dump the tank, which can only be done legally when you're out in the Gulf at least 3 miles outside Tampa Bay.On our 38 Hunter, on the control panel there is the Macerator switch. Is this to be turned on at all times or for certain periods of times after use of the restroom?
Aw man, that a looooong way to go to get pumped out.in the Gulf at least 3 miles outside Tampa Bay.
He's in Tampa, where I'm sure he can get pumped out. And I hope he plans to do a lot of sailing outside Tampa Bay in the Gulf...staying in Tampa Bay all the time can get pretty boring.Aw man, that a looooong way to go to get pumped out.![]()
