Macerating waste doesn't prevent clogs...
Clogs only happen when...a) something is flushed that shouldn't have been, and which will most likely jam up a macerator before it ever gets to the plumbing...b)when the toilet isn't flushed long enough to move solids and TP all the way through the system, so it builds up in valves and at bends....c) when sea water mineral buildup reduces discharge hose diameter and starts to trap waste, increasing the buildup. Any of the above is just as likely to happen whether the waste is macerated or not. Solids are broken up by the pump and the joker valve, so they dissolve very quickly whether macerated or not.The "aerobic process" doesn't apply to toilets or the plumbing, only in tanks. If you put a fan on the vent line, you'll need two vents...just pulling air in won't do much 'cuz it has nowhere to go. And the fan should exhaust (pull air through the tank), not pull air in to work efficiently. However, on most boats a fan is unnecessary if the vent line is straight, relatively short (<5') and at least 1" diameter. It's only when the vent line is long and travels a path with bends that any assistance from a fan is needed. Putting a filter inline defeats the whole purpose of increasing ventilation...it becomes a blockage.Increasing ventilation above the surface is NOT aeration...aeration oxygenates the waste by mixing air with it. And unlike aeration, just increasing ventilation will NOT eliminate odor without the use of an organic or bio-active tank product too. If the tank is functioning aerobically, it should be odor-free from the get-go. Aerobic breakdown doesn't convert anaerobic to aerobic...in fact, once a tank has turned anaerobic, the only cure is to pump it out, flush it out and start it over. I believe the UK company you refer to is actually Tek-Tanks http://www.tek-tanks.com/Pages/frameset.htm Their "Sanitation Guide" was adapted (with permission) from my book. Finally, I would not put a motor on your Groco model K. The only thing that putting a motor on manual toilet does is replace the pump HANDLE...you still have the same manual pump to maintain. If you want the "push button convenience" of an electric toilet, replace your manual with one designed to BE an electric toilet, not a "hybrid." Besides, there's no advantage to a toilet that can be converted to manual in the event of a power failure...'cuz if you don't have enough power to flush an electric toilet, you don't have enough to power anythng else either--no electronics, no lights, maybe no steering either, no bilge pumps...but you WILL still have a bucket. So whether you can flush a toilet or not would be the LEAST of your worries!Bill, methane IS odorless, but it's an ANAEROBIC gas...not generated in aerobic conditions. As organic matter breaks down aerobically, it produces only odorless CO2. Compost is a good example of how the aerobic process works.
