My B331 is equipped with a macerator pump. When using the pump, should the valve (not the thru hull) be pointing to the holding tank or outside discharge? Of course the thru hull to outside discharge would be open.
I pull mine down which would bring it to the outside discharge. Try looking in your Beneteau manual or the package that your dealer gave you all the information should be in thereCharlie
