MACERATOR PUMP
Scott
Peggy, should I expect the macerator pump which is installed approx. 4 feet above the holding tank in my hunter 28.5 to self prime? It is a Shurflo brand. At present it will not pump out my holding tank. The manual pump that was previously installed at this height was working fine.
Peggie Hall/Head Mistress
4' is way too high...
A manual pump doesn't have an impeller, so you can just keep pumping till it primes, no matter how far it has to be pumped till it does. But electric macerator pumps use an impeller to pump waste...if the macerator is too far or too high, the impeller has to run dry so long that friction heat fries it before it can prime. That's why it's not working. And it prob'ly won't work after you move it till you replace the impeller. Electric macerators should be as close to the tank as possible, and ideally at or below the same level as the tank discharge fitting or y-valve. The higher it has be, the closer to the tank it has to be.
