Macerator on hunter 306?
1
Hunter 306 Jax,fl.
Does anyone know where the macerator is on a Hunter 306 2002? Mine is stuck and throws the breaker when I push the button, I am sure it is stuck from sitting. Does anyone have any tips on replacing it. Thanks Bob
Jan 4, 2006
7,268
Assuming It's a Jabsco ...................
.......................... make sure you try rotating the impeller before upending the whole thing over the side.
1,346
I do not have a Hunter - but finding it should not be a problem. Just follow the hoses that are attached to the Holding tank. I replaced my macerator pump with no trouble at all. I installed the one that Ralph has listed above. Its 1" output port can be rotated to any North, South, East and West direction. If you need more info and photos send me a message.
Roddie
Nov 15, 2010
23
Hunter 306 Blaine
It is behind the rear berth on the port side mounted on the floor by the fuel tank. Just replaced mine
Nov 7, 2008
22
Hunter 290 Shoreline Marina, Long Beach
pump out clean and have rags and plastic bags handy to catch possible hose liquid. You probably have a Jabsco Macerator and try rotating the impeller screw (which may be rubber capped) as others suggested.
