Hello all,
First post. I am the proud owner of a 1986 Catalina 30. This is the second year of ownership. While looking at my fresh water pump, I discovered that the hose leading from my macerator to the thru hull was unrestricted. I know this is in violation and I want to correct ASAP. However, the plastic lever on the thru hull will not accommodate a lock and I don't really know how else to eliminate the circuit short of disconnecting the hose. Even then, I'm not sure that would be in compliance. Any thoughts?
Thanks
Jeff
Thanks
Jeff
