		Justin
Peggie,I recall a while ago a discussion about manual discharge pumps. I'm not to fond of electric macerator pumps as they don't seem to fit the KISS principle real well.Is a manual pump a reasonable long term solution. What is a good brand?We are heading to Mexico where pumpouts are scarce and at present we don't have a way of pumping overboard from the tank, only vacuum sucking thru a deck fitting. We do have a discharge thru-hull that can be used direct from the head so I suppose some replumbing is in order.It seems a shame to change the plumbing so that everything must go into the tank first before pumping overboard. Is there a better option?
