Macerator add on?
L
Lyn
I have a '82 Hunter 27' and thought of adding a macerator pump for the holding tank. Any suggestions the best way to do it or if I even should?
Peggie Hall/Head Mistress
Whether you should depends on
whether you can legally use it. In the US, you must be at least 3 miles offshore to dump a tank. That's NOT just 3 miles from nearest shore in a lake, bay or sound...that's 3 miles out to sea from the nearest point on the whole US coastline (6, 9 or 12 miles out in the Gulf in some parts of FL). As for how to do it: break your pumpout line near the tank. Install a y-valve--one side going to the deck pumpout fitting... the other side goes through the macerator, up and over a vented loop, and out a below-waterline through-hull that should ALWAYS remain closed except when actually dumping the tank. Follow the directions that come with the macerator to wire it. Before someone asks why a y-valve instead of only a tee or wye fitting...a y-valve--which should always be aimed toward the deck fitting except when actually dumping the tank--is not only a back-up fail-safe for the seacock, but allows you to cut off the flow of waste to the macerator to replace the impeller...impellers NEVER fail when a tank is empty. So why not just put the macerator above the tank? Because the further away from the tank discharge fitting it is, the longer it takes to prime...and the longer it takes to prime, the longer the impeller has to run dry...and running dry is what fries impellers.
Jim Arthur
What about AirHead
Have you considered the AirHead? It's a totally self-contained unit in which liquids and solids are separated. The solids are then composted. Certainly no legal issues here. Peggy, I would be interested in your comments. Thanks, Jim
All I know is what I read on their website
From the FAQ at http://www.airheadtoilet.com/Index/FAQx.html : "A: Once solid matter enters the main tank the foul-smelling anaerobic bacteria dies in a few days..." A few days?? What about odors meanwhile? Besides, the anaerobic bacteria DON'T die. Bacteria is bacteria...it either functions aerobically or anaerobically. The system only oxygenates the waste to eventually allow the bacteria to function aerobically. Excess liquids are drained off into a tank that has to be carried off the boat and emptied. The more people aboard, the more liquids vs solids there are. The dried solids can't be dumped overboard inside the "3 mile limit" either...see "Where do you empty the solids?" in their same FAQ. IMO, anyone who installs one has a great conversation piece, but only trades one set of issues for another. So whether it's good idea depends on what KIND of problems you'd prefer to deal with.
