Tank Hiding
Tom,Though I have not yet done it, I have been planning on cutting a hole in the vertical wall of the port side cockpit seat. I will then glass in a "box" that is open on the side, with a slight upward taper to the floor for drainage reasons and slide the tank in there. By leaving it open, I will not run the risk of trapping fumes and with the angled bottom, any fuel spills would run right into the cockpit and down the drain.One of these days that project will make it to the top of the list...until then, I will continue doing what you do...on the floor in the way.Hope this gives you an idea or two.-Mark'83 M25
