A
AndyS
The Mac 26M has a rotating mast.My initial set-up to lead the halyard back to the cockpit uses a block mounted on the bottom of the mast step (on the rotating part), then a block on the starboard lifeline stanchion.Here's the rub: when the halyard is run like this and cinched up tight - it rotates the mast all the way to the right and holds it there, not allowing it to rotate at all as you trim the sail or tack.Given that the halyard block at the top of the mast is on the starboard side of the mast, I'm wondering if a block mounted on deck would allow it to rotate.Does anyone have either a 26M or another rotating mast set-up (catamaran?) that has the halyard led aft sussessfully? I like to singlehand so I really want the line led aft.Thanks,AndyS
