keel gasket
I have just been through this on my Mac25.I got worried that the keel bolt had never been replaced so I did replace it with parts from Havencraft in Mass. To do the replacement, I put the boat on the trailer, blocked the keel on the axle with some 2x4 pieces and shim pieces. I also used a hydraulic jack on the forward nose of the keel which took some of the pressure off. Then (quickly) I loosened and replaced the keel bolt and gaskets. On the gaskets I used 4500 seating caulk and there is no leakage at all. By the way, the old bolt looked just fine so this was probably quite unnecessary.For your purposes, I wouldn't do anything unless you are getting some leakage. If theleakage is there and a problem, I think I'd try blocking the keel and raise it a little as I did but instead of taking the bolt all teh way out, just loosen it enough to put some of the 4500 caulk in on both insides of the gaskets on each side and then tightem it back up. That should work just fine.Hope this helps.Dave Schillerdschil3870@aol.com
