Hi alll,
My M5411 Runs like a top...I'm pretty satisfied with the engine even though most folks say its underpowered. Anyhow...
This weekend I noticed that the engine was starting to run hot. It had been previously cycling above 150 F to approximately 180 F then the thermostat would open and bring the engine water temp back around 135 F then start trending up again. This cycle would repeat itself about every three minutes or so while underway at about 2000 rpm. This weekend however it climbed above 180 and didn't start to come down. We stoppped the engine and limped back to the mooring.
This morning I pulled the thermostat and noticed that there was something blocking the engine water outlet into the thermostat housing. I got some stiff copper wire and was able to dislodge it. It appeared to be rusty scale. I put everything back together and ran as previously described. My two questions are:
1. Should a Thermostat cycle up and down like that? Or do you think it needs to be replaced?
2. Is rusty scale a sign of something catestrophic? or can that be expected in a 30 year old raw water cooled engine? Is there anything I can do to flush?
Thanks in advance,
Sean
Thanks in advance,
Sean
