M25 maintenance
112
Catalina 30 Downtown//Shoreline Marina, Long Beach
The Universal M25 manual suggest routine maintenance every 100 hours. I would rather schedule annual check ups, even though my engine is only two years young and has less than a total of 100 on it. What say y'all?
Jul 25, 2009
270
Catalina 1989 C30 Mk II Herrington Harbour South, MD
Nothing wrong with doing it more often, especially if it puts you in a habit to take care of things on a regular schedule.
Depends on how often you use the engine, and whether or not you always bring the engine temperature up to operating speed when you do.
We bought our boat with 888 engine hours (1986 boat, bought in 1998). We now have 2400 eh.
Fuel filters: primary Racor, secondary engine mounted; I put off doing the Racor for years when we first got the boat 'cuz I was "terrible feared" about bleeding and never getting it going again!!! Piece of cake. This will help you: http://c34.org/bbs/index.php/topic,2884.0.html. Secondary I do every two or three primary changes. Frequency: 150 eh.
Oil filter: I check the dipstick every time before I start the engine. Usually change this filter once a season or so, 100 to 150 hours as well, sometimes less. I built a connector from the oil pan drain line to a manual hand pump. There are all sorts of oil extractors out there.
If I haven't sent you here yet, try our C34 Tech wiki, engines: http://www.c34.org/wiki/index.php?title=Diesel_Engine
We generally run our engine almost twice as much as the "regular" 100 eh/year. We have a 45 minute run to open water out and back, so it gets a lot of use and were using it once a week, almost all year long (up until my skiing accident two years ago).
Take care of your engine, it'll take care of you.
Jan 4, 2006
262
Catalina 36 MKII Buford, Ga.
The best advice is to run your diesel often and long enough time to get up to operating temperature...they like to be worked. The WORST thing is to run the diesel for a short time (just out of the marina) and turn it off and go sailing.
Now to your question. I sail on an inland lake and have a hard time getting to 100 hours a year, so I change my oil and filter 1 time per year along with the transmission fluid. I do my primary Racor fuel filter about every 18 months and the secondary fuel filter every 2 years.
