M 25 Universal wiring harness
Phil
Our M 25 Diesel has hesitated to start at times following the 30 second hold of the glow plug button and pushing the start button. A fellow boater mentioned connectors that were available as an upgrade on the wiring harness. Torresen Marine Diesel had no information on an upgrade, but does sell a new harness and extensions to reach the switch panel. Has anyone had any experience with similar starting hesitation? What is the method to better insure a consistant start? Thanks, Phil
Jun 11, 2004
1,772
Oday 31 Redondo Beach
check the link
Universal service bulletin 213. If you have intermittent cranking problems what you probably need to do is replace the wire mentioned in item 3. Not too hard to do and worked like a charm for me. If it cranks well but doesn't start you may need to replace the wire to the glow plug. Use #10 wire here is a link to the wiring diagram: http://www.marinedieseldirect.com/universal/200157/universal-owners-wiring-diagram.html Or, post the question in the ask all sailors section and Stu Jackson can probably link you to something in the Catalina site that talks about a complete wiring harness replacement.
