While measuring your sail
will get you pretty close to the luff length, it may not give you the maximum length your boat can or should carry. You would have to stretch out the sail's luff the same way/distance it is stretched when hoisted. Measuring the actual luff, but running a line up the halyard, and then measuring that length, is far more accurate -- if accuracy is the object.
