Think about this
Morning Bill:There may be some cons to my method by naysayers but I've been using it for years now on my main and never had any problems.I use a small section, about two inches, of 3/8 to 1/2 inch line, whipped on the ends to keep it from fraying. Whatever size that will fit into your track loose enough to travel will be fine. This is inserted in the track between the top two slugs and left there. I keep it lubricated with WD40. Everytime I raise and lower the main, it sweeps any dust or grime out of the track and lubricates it at the same time, from top to bottom. I've never had any problem and it really helps the raising and lowering of the main. If you decide to try this, experiment with it while at dock to make sure that you have the right fit and that you don't experience any jambing problems. If you don't feel comfortable with leaving it in the track, it can be taken out after you get your track cleaned and lubed. I've never had much success at the foresail issue, but fortunately, it's not something that has to be dealt with on a regular basis.Luck!
