Lubricating mast step studs
Smitty
Sep 16, 2005
108
Cal 28-2 Milford, CT
My Cal 28-2 has 6 studs that stick up through the mast step for turning blocks for halyards etc. They were frozen up and wouldn't turn to allow the blocks to find a natural position. I freed them using PB Blaster (which worked great BTW), but now how can I get some lubricant into them and what should I use? I'd really like to keep them free now that they're working the way they should.
estopa
Feb 27, 2008
182
Oday 222 Milford, CT
I use some spray silicone from the auto parts store. I think you could spring for the $$$ stuff by looking up sailkote I believe.
Aug 16, 2006
281
Ericson 32 Oregon coast
Some people like Inox for keeping fasteners corrosion
and free. It is a lot like WD-40 but a little longer lasting in weather.
Ross
Jun 15, 2004
14,693
Re: Some people like Inox for keeping fasteners corrosion
I would and do use plumbers teflon pipe joint compound.
Edit to add: I don't allow silicone spray on my boat.
Jan 4, 2006
262
Catalina 36 MKII Buford, Ga.
If you like the "PB" products (as I do), they also make a lubricating spray with corrosion protection.
