lubricate steering
C
Chris H
My owners manual says to follow the manufacturer's instructions, which I don't have. I have an Edson steering mechanism on a H-340. Any suggestions on what lubricant to use to lube the joints in the steering linkage? Thanks. Chris H.
Rich Stidger
Get an Edson Catalog
Chris, Edson details in their catalog the steps required for yearly maintenance. You will need to figure out which model steering that you have, but that should be fairly simple by visual inspection. If you are still in the dark, simply call Edson. I have found them and their 'sudden service' to be very helpful. Rich
Terry arnold
steering inspection and maintenance
check this article. Also, the edson catalog is online and can be downloaded in .pdf format. http://www.sailnet.com/collections/articles/index.cfm?articleid=keenew001
E
Ed Schenck
Edson seconded.
When I ordered my Edson catalog from their web-site the form asked for my own boat model and year. When I received the catalog they had included separate detail for the exact unit that was installed on my 1979 H37C. How's that for service?! At any rate I just use oil from a squirt can. On the chain and sprockets, at the wheel shaft bearings, and at the turning block bearings. I also keep the cable oiled.
John
Greasing the steering system
For my 340 Edson suggests using part no 827 Teflon grease. The top rack and pinion gear and lower grease fittings should be done annually. Grease fittings are located in side the Down tube just below the Wheel Shaft. Ball joints and drag links need Teflon Grease also, annually. Just take caution not to OVER LUBRICATE. If you would like a copy of the Edson data sheet send a fax no. or email and I'll be happy to forward it to you. Hope this helps.
C
Chris H
Thanks John
Jhon, thanks for the info this is just what I was looking for. If you can send the info sheet that would be great. My email is cherndl@aol.com.
C
Chris H
Sorry John.....
I get my several email addresses confused. My real email is cdherndl@aol.com. Thanks again.
John
expect a letter
I sent you a copy of the spec sheet today. If you do not receive it let me know.
