LPG Stove Not working
Mar 29, 2011
169
Beneteau 361 Charlotte,Vt
My LPG stove on my Benetieau 361 is not working properly. I can light the burners, the flame is real low, and they go out after a few minutes. If I turn the gas bottle off and turn it back on after a few minutes. I can again light the burners, they don't stay lit. I know the bottle is full, and replaced the regulator. My next move is to check the lines for blockage, or replace the solenoid.
Thanks,
capta
Jun 4, 2009
5,072
I hope you are keeping the valve at the tank off until you figure out the problem.
Aug 16, 2011
46
Hunter 35.5 Bayfield, WI
Thanks,
It sounds like the supply line needs to be replaced.
Mar 29, 2011
169
Which supply line. Between the tank and reg, or reg to stove, and why?
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
How old is the boat? Was it original equipment?
Deteriorated line wouldn't be my first guess. It could be pinched -- but that would be something that shouldn't happen.
Regulator, solenoid, stove valve would be my first guesses.
Careful while you are working on this.
Oct 29, 2005
2,366
open the solenoid plunger and check for oil residue. Clean the valve seat and sealing face as well as the plunger.
Hunter 34 Alameda CA
The best absolute measure for a full tank is to weigh it. The empy weight should be stamped on it. Maybe while the tank is off you can borrow another one to test.
Feb 8, 2014
1,300
Columbia 36 Muskegon
The OPV valve inside the tank can go bad, trying another tank would diagnose that. Doesn't have to a marine tank, one off a home patio grill will work.
Mar 29, 2011
169
I fixed the problem. The problem was with the solenoid. Once I replaced that, the stove works great. Thanks all.
