LPG gas tank for Force 10 stove
Jun 25, 2005
72
Hunter 31 Carlyle IL
2007 H-31 equipped with a Force 10 stove. The 11 lb. LPG tank is dated 2006. There is no rust and appears in good condition. Is there a Coast Guard or other regulatory issue that requires replacement after a certain time?
Thanks
Take the tank to a qualified Propane gas facility. They can inspect repair and"certify" the tank. These tanks have a certification life of about 6 years as I remember. I have 2 that were of unknown date and condition. I took them in and left them with the service manager. Came back in 2 days. They charged about $30. I think it's been over 18 months.. and replaced the valves or parts needed giving each a certification stamp. Good to go.
Sep 11, 2011
428
Hunter 41AC Bayfield WI, Lake Superior
in the US you get 12 years from date stamp on the tank. If you get it recertified I believe that you get another 5 years.
Gunni
Mar 16, 2010
5,937
The regulatory requirement is that the tanks be within certification date or they are not to be filled. I take my out-of-cert tanks to my propane distributor and he inspects and stamps them at no charge. These are low-pressure vessels so you don't need a hydrostatic. They check the cylinder condition, the valve and the pop-off vent. I assume you have an aluminum cylinder, if not that would be a good upgrade.
