Lowering the Keel
Feb 24, 2009
89
Beneteau 36cc Fort Myers
Recently bought a 1975 swing keel, had the bottom done, motored home with the keel UP. Now a really dumb question - how do I operate the crank to LOWER the keel????? I know I unlock the hold down bolt, but then what?
Apr 26, 2010
434
catalina 22 lake tillery NC
then rotate the winch handle counter clock wise. you will feel it ease up when the keel is full down.
Feb 24, 2009
89
What keeps it from lowering by itself - no ratchet or anything? My handle has a spring mechanism on it but I don't know how it works?
Apr 26, 2010
434
it has something like a clutch set up i'm not sure of the mech. on it but that's how it works.
Sep 8, 2014
2,551
There should be no lock mechanism on your winch, if there is one then you are in trouble! the type of winch that uses a lock is free turning when the lock is released, that is the type of winch you should have on the boat trailer only.
I'm sure you have the correct type of winch because you mentioned the spring at the base of the crank handle. Yes, as Piper pointed out it has to do with the clutch mechanism. On the keel winch you should be able to crank the handle in either direction but it will always be in a controlled manner, the winch will never freewheel. It can only raise or lower the keel as fast as the handle can be turned.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
Just wanted to add that when sailing, make sure the keel is all the way down. My first time out on my C22 swing keel I was not impressed. I thought that this thing tracks like crap. I found out I was not all the way down. Not sure if the cable was wedged on the spool or what. I first cranked it up a little and then down faster until I heard a thump. Tracked great then :)
Feb 24, 2009
89
Thank You
Thank you all very much for your quick and helpful responses!
