F
freshies4me
I have an 1982 Catalina 30. On the port side, forward lower shroud has pulled the deck up about 1/2-1/4 inch. Down below the shroud is connected to a L shaped bracket. It is not connected to any bulkhead, it basically just a backing plate. I an going to replace the L shaped bracket with one that will connect to the bulkhead. Any suggestions about what to do to the deck. I loosened the shroud and the deck did not lower. Before I bought the boat the deck was redone using a foam core. Any one else have this problem? any suggestions?
