Hi,
Where can I get the bushing or synthetic insert at the lower end of the rudder shaft? Taken the shoe off and it is worn out on one side.
#2, as I was turning the prop shaft, I noted that some plastic has oozed out and was turning with the shaft. Is this the end of the cutlass bearing? I don't think it is supposed to turn , again, where where can I get one?
Thanks, Emil.[Non-text portions of this message have been removed]
