Lower bracket on the rudder
5
hunter 1984 25.5 Southport, NC
Was it standard practice to use phillips heads on the outside of the haul on the lower rudder brackets? I'm going to temp seal these and tighten them down. I am moving the girl from the upper cape fear to the lower and I'm surprised that these key fasteners would be phillips head rather a bolt head. I can see that it has leeked in the past but it sits just above the water line.
Oct 3, 2006
1,029
Hunter 29.5 Toms River
Tightening the nuts on the inside, it really doesn't make a difference if the guy outside is holding a wrench or a screwdriver.
