I have a 2005 3YM20 Yanmar motor in my 2006 Catalina 309 sailboat. It has only 330 hours in it. Recently, it cannot go higher than 2500 RPM. I have changed oils, filters according to the user’s manual. A local Yanmar technician also adjusted the valves the last fall. I don’t know if it is related, but since tehn, only occasionally, I have experienced the lower RMP problem. When I called him he said it must have been the barnacles on the bottom of the boat. Today morning, as usual, a diver cleaned the bottom and the prop. Still, the RMP, in the dock, does not go higher than 2500. I also checked the transmission and throttle cables, they are fine in length. When I disengage the transmission from the motor, the RMP can go all the way to 3600. Has anybody experienced similar problem?
Tibor Gyires
Catalina 309, “30”, Charlotte
St. Pete Beach
Tibor Gyires
St. Pete Beach
