H
Howard Morton
Having just bought a 1984 C30 equipped with a Universal M25 (600 hrs), we had the local diesel guy go through it completely to determine its condition. Everything checked out fine, and the engine seems to run quite well. We generally use it only to get in and out of harbor, preferring of course sailing to motoring.One evening this wasn't possible. Got caught way out when the wind died, and we had to motor for a couple of hours. Engine temps were steady at around 190 degrees. Engine ran great, no problems. When we returned to port, and reduced speed to idle, the low pressure lights/buzzer sounded intermittently, seemingly in synch with the firing of the engine. Increasing speed caused the indications to immediately stop.What gives? Do we have a problem here, or is this normal once the engine has been used at normal operating temp for extended periods, and then slowed way down?Any insight appreciated.Howard
